The thermostat is in the block at the forward side of the engine, behind the water outlet above and left of the dipstick tube. Always repace the O-ring, install with the copper end inside the block. Do not mix coolant types unless compatability is certified. OEM is G12 (pink).
SPONSORED LINKS
Tuesday, June 8th, 2010 AT 3:55 PM
