2000 Volkswagen Jetta Starter
2000 VOLKSWAGEN JETTA
125,000 MILES • 4 CYL • FWD • MANUAL
SLATER619
When I start my Jetta, it starts fine but it sounds like I am holding the key in the start position for longer than I actually am. In other words, everytime I start the car, it starts immediately but it makes the sound like I am turning over the key when the car is already running. I assume the starter is going. Can this be repaired or does it need to be replaced? How much should repair or replacement cost?
Jan 25, 2009 at 8:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
It could either be the starter solenoid or the ignition switch. Jumper starter and see if it stays engaged after jumpering. If it does, replace starter solenoid. If not, replace switch. You can also remove starter and have shop test it for free. Estimate for replacing starter solenoid is $270. Estimate for replacing ignition switch is $125.
Thanks for using 2CarPros.com!
Jan 25, 2009 at 9:09 AM
