2000 Volkswagen Jetta several electrical failures
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARK MILLIGAN
all at once the following stopped working:power sunroof,windows,remote locks,trunk release(also key does not unlock trunk),overhead lights,mirrors.i checked all fuses and found #14 15amp was blown.as soon as i replace it it blows again.any ideas where to go from here.i must have a short or relay stuck.my wife did mention that the back side window would be hard operating sometimes.thank you for your help.
Feb 7, 2008 at 3:19 AM
JEFFGIRARD
  • 5 POSTS
Read some of the latest replies to electrical problems, as I had the same set of problems, and believe to have solved them in one task.
Mar 8, 2008 at 1:14 PM
MARK MILLIGAN
[quote:0328001262="jeffgirard"]Read some of the latest replies to electrical problems, as I had the same set of problems, and believe to have solved them in one task.[/quote:0328001262]
where would i find the info you are refering to?
thanks,mark.
Mar 10, 2008 at 7:39 AM
