2000 Volkswagen Jetta Jumping into gears
120,000 MILES • 4 CYL • FWD • AUTOMATIC
PAREJOS
The car was running normaly and then I changed my transmission filter and fulid (VW recommended). Now, when I come to a dead stop, the car feels like it goes into a lower gear. WhenI take off, the car barely moves and then all of the sudden, it jumps into the right gear and takes off. When i remember, I push the gas softly and the jump is not as hard. But most often, I push the gas normally and the jerk is really bad.
Am I in for a major transmission overhaul?
Sep 26, 2009 at 2:09 AM
KHLOW2008
  • 41,812 POSTS
Hi parejos,
Thank you for the donation.
If problem was not there prior to replacing the trans fluid and filter, I would suggest rechecking those.
1. Was the trans fluid used of the correct specifications?
2. Did you recheck the fluid level?
Sep 27, 2009 at 2:00 AM
