2000 Volkswagen Jetta electrical
95,000 MILES • 6 CYL • FWD • MANUAL
RHINO2346
I have a 2000 vr6 and the other day the electric windows stopped working along with the sun roof and interior lights. I also noticed that one of the headlights was dim and the other bright. I checked the fuses and found a 30A and A 10A blown, when i rwent to replace the 30A the minute I put it into its slot it blu. I check for abovous shorts and found none, My question is could this be a windows relay fuse gone or an ignition swicth, or where do I begin to look,
Apr 1, 2009 at 1:50 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Please give fuse number and location. Also is the 30A for windows? are interior lights and sun roof working?
Let me know
Thanks for donate
Apr 1, 2009 at 3:08 AM
RHINO2346
The fuse must have been for the windows because it is the only 30A in the box I belive it was location #35 and the iinterior lights and sunroof are also not working
Apr 1, 2009 at 3:15 AM
DOCFIXIT
  • 18,828 POSTS
O.K. trying to find something in common can link sunroof and lights a ground G202 under left side dash. Will be several black wires connected to the body. This also grounds the comfort module and it is connected to windows. Was 10A #14? Windows fuses #37 & #38. Let me know about grounds and fuses
Apr 1, 2009 at 4:33 AM
RHINO2346
The 10A was the top one all the way to the left one of the small 10A fuses(sorry I'm not at the car so I will have to get it later, and I will cheack the grounds,thank you
Apr 1, 2009 at 5:07 AM
RHINO2346
I checked for grounds and found them to be okay, I double checked all fuses and found another one had blown replaced that and the windows and internal lights all work. The 30A fuse in the # 35 slot still blows when I put it in, I left it out and tried all of the functions of the car and everything seems to work ,but I looked over all my liteture including the manual along with a haynes repair book and no where is it listed what the 30A controls also when I put it in it arcs. My problem could be solved if I knew what the #35 controls
Apr 2, 2009 at 3:24 AM
DOCFIXIT
  • 18,828 POSTS
#35 bis for a 12V outlet in trunk. Must be short to ground. Check socket and wire
Apr 3, 2009 at 8:52 AM
