2000 Volkswagen Jetta diagnostic code p1128
YORONGL
Engine Performance problem
2000 Volkswagen Jetta 4 cyl Two Wheel Drive Manual
our machine read that read long term fuel trim system to lean. what is the probable failure, and how do i fix that.
Apr 7, 2009 at 10:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Most common culprit is a faulty oxygen sensor or clogged catalytic coverter. Have converter flow tested and also test each oxygen sensor and their wiring.
Thanks for using 2CarPros.com!
Apr 7, 2009 at 11:44 AM
