The radiator fluid is not staying in the reservoir but is not leaking from the car either. We replaced a cracked flange part that seemed to be causing the leak.
When the reservoir is filled and then the engine started the fluid disappears but does not leak out of the car. Is the thermostat possibly broken?
Car is not overheating, gauge stays @ 190 degrees (right in the middle of the gauge)
Please advise.
Please advise.
Jan 16, 2010 at 1:56 PM
