2000 Volkswagen Jetta camshaft position sensor
2000 VOLKSWAGEN JETTA
105,000 MILES • 4 CYL • 2WD • MANUAL
BERGER40
where is the camshaft position sensor on a 2000 vw jetta
May 31, 2009 at 11:03 PM
JUL18
  • 7 POSTS
Yes, there is a CMP sensor on the AEG engine.
The connector is located under the engine shroud R/H (passenger side) of the engine between the cyl head and the valve cover. It does have a metal bracket that wraps around to the camshaft area (timing belt) on the cyl head.
-Juls
Jun 7, 2009 at 3:24 PM
