2000 Volkswagen Jetta
TRASK3695
Engine Performance problem
2000 Volkswagen Jetta 4 cyl Front Wheel Drive Automatic 10000. miles
car runs fine untill i shut it of to fuel it up then i go to start it and i have to hold it to the floor like it is flooded then it will start after thirty seconds of cranking and runs rough untill it clears out.
Aug 1, 2010 at 11:59 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Is this a 1.9 or a 2 litre engine?
mark (mhpautos)
Aug 1, 2010 at 12:43 PM
TRASK3695
it is a 2.0
Aug 1, 2010 at 12:54 PM
  • 31,937 POSTS
Thanks for that, as it is the 2 litre petrol engine, i would be wanting to check the fuel pressure first, also when was the filter and the plugs last check or replaced? do you get a check light? i would also do a scan as not all faults will set a MIL, let me know if there are any unresolved fault codes, start here.
mark (mhpautos)
Aug 1, 2010 at 1:43 PM
TRASK3695
Thank you, I will check that and get back to you. Have a good night.
Steve
Aug 1, 2010 at 3:14 PM
