1999 Volkswagen Jetta value damage with timing chain breaka
1999 VOLKSWAGEN JETTA
R DIXON
Engine Mechanical problem
1999 Volkswagen Jetta 6 cyl Front Wheel Drive 90000 miles
i have recdntly came to the owner of a 1999 vw jetta gls vr6 was told that the only problem was the timing chain was broken. several techs tell me that this automatically means the values have been damaged and either i should replace engine or have a overhaul done
what is true or which is best
Oct 24, 2010 at 11:55 AM
BILLYMAC
  • 2,204 POSTS
what i would is put a new chain in it and see if it runs if not then plan on valve job
Oct 24, 2010 at 12:55 PM
