1999 Volkswagen Jetta Horn
245,000 MILES • 4 CYL • 2WD • AUTOMATIC
COLIN BARRIE
I have a 1999 VW Jetta GL, The horn sounds if you use the keyless entry for locking the doors and panic button but the horn will not sound if you are pressing the buttons on the steering wheel.
Apr 10, 2008 at 11:47 PM
FRIZB99
This is because there are acutally 3 horns on a VW. The alarm horn has its own dedicated horn. The actual horn that is activated when using your steering wheel is 2 different harmonizing tones. If you have a MK4 jetta (99.5-2005) then the horn is behind the bumper cover on the driver side. Previous models are somewhere on the passenger side. I would suggest getting a helper and have him/her press the horn while you test for voltage at the horn terminals with a multimeter.
Apr 14, 2021 at 4:00 AM
