1999 Volkswagen Jetta clutch
1999 VOLKSWAGEN JETTA
ANDREA1234
Engine Mechanical problem
1999 Volkswagen Jetta 4 cyl Front Wheel Drive Manual
my car will go in every gear but it dont move when i realase the clutch motor does not die
Aug 4, 2009 at 1:25 PM
MIKE_07
i had the same problem on my gti. the clutch was not engaging becuase the throwout bearing had fallen apart.
Aug 10, 2009 at 7:15 AM
GEARBOX TECH
  • 12 POSTS
most likely problem is the clutch is burnt out if it was the release bearing he car wouldnot go into gear with theengine running another common problem is that the rivet that hold the crownwheel to the differential are known to shear off.
Sep 6, 2009 at 9:19 AM
