1998 Volkswagen Jetta trans fluid
1998 VOLKSWAGEN JETTA
228,222 MILES • 6 CYL • FWD • AUTOMATIC
DEEMAN123
how do i add transmission fluid
Nov 5, 2009 at 7:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
run the car in park with the 5mm hex plug removed from the bottom of transmission pan. If there is fluid coming out while running (make sure car is up to operating temp), then it is full. If not, remove the red cap from the transmission then take out the plug and fill untill it comes out of the hole that the 5mm plug was removed from. use only VW approved fluid.
Nov 5, 2009 at 7:21 AM
