Engine Mechanical problem
1998 Volkswagen Jetta 4 cyl Front Wheel Drive Manual
my timing belt came off without me notice it i start the car and it did not turn on so i try to start it again someone tell me that i may cause damage to the heads and probably the valves are bent it's true?
i find out the tensioner came off the bracket causing the time belt to not run s i just want to know if i can just call my mechanic to put the car on time again or if the damage is irreverseable and i have to replace the motor please advise please and thank you
Nov 23, 2009 at 5:10 PM
