[quote:788d0fef4b="KHLow2008"]After replacement of the ECT, was the trouble code
cleared and did the CEL return?
Was the ECT used OEM and was any reading tests carried out on it?
When it was dificult to start, was the engine cranking speed good?
Did you test the fuel pressure?
Are the spark plugs conditions good?
Any idea of the spark plugs burning condition?[/quote:788d0fef4b]
After i replaced it, the code went away and it never came back anymore as of now that i know of.
The cranking was good when i try to start it, i did notice a little bit of black smoke coming out from the exhaust. But it then went away.
I havnt had the chance to do the fuel pressure test, but i will soon. Maybe tomorrow..
I put in new spark plugs about two years. I got those bosch fusion, which they were expensive. I replaced the plug wires too. I would have to take one out to see what the burning condition is, it shouldnt be that bad...
I did had some problems before with my idling because it was a little high. So i cleaned the throttle body and replaced the IAT sensor and it stopped doing that.
Last year the long block got replaced. I put a new one. I'm trying to think whatelse have i changed. Well, i will let you know if i can think of anything else.
I really appreciate ur help.
Nov 19, 2009 at 6:36 AM
