How do you take a fuel pump off on this car? Does it have clips or something it seems stuck.
Sunday, January 24th, 2010 AT 10:33 AM
BLUELIGHTNIN6
MECHANIC
Must use special tool (a ring nut spanner) to remove the screw cap. . Then remove the flange and sealing ring from fuel tank opening. Loosen the fuel pump module from the bayonet connection by turning to left and remove.
