1996 Volkswagen Jetta ignition or fuel pump?
KURTT
  • 1996 VOLKSWAGEN JETTA
Electrical problem
1996 Volkswagen Jetta 4 cyl Front Wheel Drive Manual
Car quit while my wife was driving home. Upon inspection, discovered that battery was strong and car was cranking, but won't start, suspect either no spark or no fuel? How to tell which it is?
Wednesday, February 17th, 2010 AT 10:04 AM
STEVEW84
  • 673 POSTS
To test for fuel you have to hook up a a fuel gauge in line with the fuel hose. To test for spark you have to get a spark tester and hook it up between the ignition cable/ignition coil and a ground point or the spark plug.
Friday, February 19th, 2010 AT 10:16 PM
