1998 Volkswagen Jetta 1998 VW Jetta Power Window Problem
1998 VOLKSWAGEN JETTA
146,000 MILES • 4 CYL • 2WD • MANUAL
MRRY0703
1998 VW Jetta GLS Manual Trans. The driver side power window won't roll down. It was working until today, but the "one touch down/up" feature has been sporadic. From the same switch the front passenger window won't up but will roll down. The passenger side switch works fine; passenger window goes up and down... for now. The drivers side rear window won't roll up or down from dash switch or door switch. The passenger side rear window switch works from dash and from rear switch. Any ideas how I might be able to fix this? I am most interested in getting the driver's side front window working correctly.
Mar 11, 2010 at 1:45 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation . much appreciated
I would start by checking or replacing the main window switch .. check you have power to and from the switch in all positions ? .. also check you have power going to the window motor and control module !
Mar 12, 2010 at 7:41 AM
