I have a 97 Jetta A/T that seems to be stuck in the 3rd gear limp home mode. I have CELS for B1S1 O2S, MAF sensor, Torque Converter solenoid, Shift solenoid D, ECM output issue? and incorrect gear ratios. I am replacing the O2S and MAF today but if this does not fix the issue what is the next step to go towards? Check trans level (would have already done but it's a sealed unit), or replace solenoids, where are these located? Also have read on AllData it could be a possible grounding issue? PLEASE HELP as I am already ~2weeks over for smog test!!!! THANK YOU in advanced!!!!
Aug 17, 2009 at 7:53 PM
