1997 Volkswagen Jetta Speedometer
1997 VOLKSWAGEN JETTA
137,000 MILES • 4 CYL • 2WD • MANUAL
CHELITO46
I have a 1997 VW jetta 2.0 manual that suddenly started to have the speedometer indicator bounce up and down, it would at times go from 0mph to 100mph while driving it. It would not have an accurate reading. Can you be able to help me on this?
Thanks
Jul 29, 2009 at 5:04 AM
GEARBOX TECH
  • 12 POSTS
Hi i have never seen a sender unit give trouble if you take it out of the box you can turn it with a drill with the ignition on if you keep the drill speed constant it should stay constant on the dash .Check the teeth on the worm drive when it is out , it is not in the box as the drive is steel . I know that there used to a problem with a resistor in the speedo clock circut, also Check for chaffed wiring or bad earths although i think this is a long shot in your case.
Sep 6, 2009 at 9:48 AM
