Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volkswagen
Jetta
Steering
Pump
Replace/Remove
1997 Volkswagen Jetta Power Steering Pump replacement
1997 VOLKSWAGEN JETTA
89,000 MILES • 4 CYL • FWD • AUTOMATIC
GEENME
MEMBER
1 POST
Is there a special tool required to remove the Power Steering Pump pulley? and also to install onto replacement unit? If so, what is it called?
Apr 29, 2009 at 12:05 PM
Experienced Mechanic
Either you have it drill pressed or use a puller that looks like below
Apr 29, 2009 at 7:57 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
