1997 Volkswagen Jetta Car Stall and won't start
100,000 MILES • 6 CYL • FWD • MANUAL
ARFY
One night the car wouldn't start for 30-45 minutes. It would definitely turn over, just not start. This happened every once in a while. Then eventually it started stalling while I was driving. It think this only happened when I had the clutch all the way in so the engine was at idle. I put a new fuel filter, fuel pump and ignition coil in it. None of these fixed the problem.
Update: My repair guy says it's the crankshaft sensor. about $195 parts and labor.
Oct 9, 2010 at 1:06 PM
  • 110,248 POSTS
When it doesn't restart, are you getting spark and fuel to the engine?
Dec 20, 2016 at 3:55 AM
ARFY
Can't say for sure. Never had the tools or help in the middle of the road to check. I pretty sure I'm getting fuel. I just got an idea from my brother in law that it might be the spark plug wires. They could be worn out.
  • 110,248 POSTS
They wouldn't have all gone completely bad at one time. You would have experienced a miss first. Somthing tells me you are either losing spark or fuel pressure when it happens. If you need directions as to how to check it, let me know.
