1997 Volkswagen Jetta
83,000 MILES • 4 CYL • FWD • MANUAL
MARCCAZES
cluch pedal goes to floor car will not move
Nov 1, 2008 at 11:52 PM
MMPRINCE4000
  • 8,548 POSTS
Bleed the clutch system from the slave cylinder, make sure the clutch MC does not run out of fluid.
Once bled, have someone push clutch and watch slave rod, if it moves you are OK, if not, then check for leaks in the system. If no leaks, the replace the clutch MC.
If slave still does not move after replacing MC, then replace slave, re-bleed system.
Nov 2, 2008 at 12:19 AM
