1996 Volkswagen Jetta power windows and power door lock don
150,000 MILES • 4 CYL • FWD • MANUAL
SCITRULLO
using the key the power windows wont go down, but they will go up. the power locks dont work with the key. the power windows only go down from the inside
Nov 7, 2009 at 3:29 AM
DR LOOT
  • 2,311 POSTS
Have you checked your fuses? most likely the module inside the door, that is attached to the lock has malfunctioned, you will have to remove the door panel. To do the diagnosis on the switch.
Nov 17, 2009 at 2:33 PM
