1996 Volkswagen Jetta Jetta 96 overheating
140,000 MILES • 4 CYL • FWD • MANUAL
ADAL
I replace the thermostat and water pump, then I test the thermoswitch and it's working properly but the radiator fans never turn on then my car still overheating.
I test the FAN jumpering the thermoswitch connector on both speeds and the fans works.
The radiator inlet hose is hot and the outlet hose is hot too, but not hottes that the inlet one.
Actaully I don't know what else can I check or test
coolant temp sensor?
radiator?
I'll appreciate your support
Mar 22, 2008 at 7:14 PM
  • 75,988 POSTS
Check all the fuses and the coolant fan control module at left side of engine compartment-
Mar 23, 2008 at 8:04 AM
