1996 Volkswagen Jetta hard starting
19,400 MILES • 4 CYL • 2WD • MANUAL
PAUL109
My Jetta is not firing while cranking the starter. when I turn loose of the the key to the run position it will fire the plugs if the engine is still rolling. I can start it if I keep doing this, but is very had to start.There should be something that maintains power to the inginistion while cranking the engine
Dec 27, 2007 at 11:56 AM
STATOR
I have a 97 sounds like same problem,did you ever figure it out?
Apr 27, 2008 at 12:19 PM
