My Jetta is not firing while cranking the starter. When I turn loose of the the key to the run position it will fire the plugs if the engine is still rolling. I can start it if I keep doing this, but is very had to start. There should be something that maintains power to the inginistion while cranking the engine
SPONSORED LINKS
Thursday, December 27th, 2007 AT 7:56 PM
