1996 Volkswagen Jetta Adding Transmission Fluid
165,000 MILES • 4 CYL • FWD • MANUAL
CRDUSKEY
My car was leaking what I thought was oil, took it to get the oil changed and they said it was the transmission fluid, it's been leaking for a few months, is adding more fluid something I can do or do I need to take it to a mechanic and how much will that run approximately?
Jul 16, 2008 at 9:05 AM
KHLOW2008
  • 41,812 POSTS
Hi crduskey,
Topping up is not the solution, you need to get it repaired.
It depends on what needs t be done so unable to give you any estimates.
Jul 17, 2008 at 6:59 AM
