1996 Volkswagen Jetta
RROBERTT
  • 13 POSTS
I think maybe I'm not being clear enough on my qestion......,I need the relay marker #'s and what slot they go in for the ones right above the fuses.You sent where the relays go but not the marker #'s.Thank You
Aug 1, 2010 at 3:09 AM
  • 75,988 POSTS
Relay Location On Fuse/relay Panel
https://images.2carpros.com/forum/automotive_pictures/12900_f_8.jpg
Important! Obtain radio security code and disconnect battery ground strap before working on electrical system. NOTE: Relay and fuse location may not match those shown below depending on vehicle accessories and optional equipment. See appropriate wiring diagrams. Number in parentheses indicates production control number stamped on relay housing. Relay locations on fuse/relay panel 1 - A/C Relay (13) 2 - Rear Window Wiper/Washer Relay (72) 3 - ECM (Engine control Module) 3 - Power Supply Relay (30, 109, 288) 4 - Load Reduction Relay (18) 5 - Open 6 - Emergency Flasher Relay (21) 7 - Open 8 - Washer/Wiper Intermittent Relay (19, 99) 9 - Seat Belt Warning System Relay (4, 29) 10 - Fog Light Relay 11 - Dual-Horn Relay (53) Or Bridge For Horn 12 - Fuel Pump Relay (67, 80,167) Or Glow Plug Relay (102,104) Separate relays above fuse/relay panel 13 - Heated Oxygen Sensor (HO2S) Control Module 14 - Park/Neutral Position Relay (150) 15 - Open 16 - Open 17 - Open 18 - Open 19 - Open 20 - Open 21 - Open 22 - Open 23 - Open 24 - Open
Aug 1, 2010 at 4:34 PM
