1995 Volkswagen Jetta won't start
135,000 MILES • 4 CYL • FWD • AUTOMATIC
RICRAK
95 jetta 111 GL
If i turn the key on to start i get nothing, no clicking as if a bad battery. I replaced the battery, starter.
The start relay seems good, felt movement on the relay. tried to start in park and all of the other gears, nothing. On the shift lever I get movement on the park, netural saftey switch.
When I replaced the starter it still would do nothing, I turned the wheels and it started, but only once, tried again but nothing.
I am stumped
Jun 21, 2009 at 7:36 AM
BUDDYCRAIGG
  • 2,262 POSTS
there's no quick easy answer here.
You're going to have to get a test light and start checking to see where the power is and isn't.
Having a schematic would definitely help, but the chain probably goes something like this.
Battery, fuse box, ignition switch, inhibitor (neutral safety) switch, starter relay, starter.
good luck
Dec 20, 2016 at 3:29 AM
RICRAK
I took it to a garage and they found some frayed wires at the battery and thru the firewall. they replaced the ignition switch due to internal arcing. I picked up the car ,drove it home, and now it won't start again. I am going to replace the starter relay,I guess thats the only thing left.Of course I am going to call the garage back
BUDDYCRAIGG
  • 2,262 POSTS
any updates after you replaced the relay?
