1995 Volkswagen Jetta Turns over but won't start.
PITT51
  • 15 POSTS
Engine Performance problem
1995 Volkswagen Jetta 4 cyl Front Wheel Drive Automatic
Just replaced timing belt and water pump put it all back together and now it turns over but won't start. Seems to not be getting spark and was fine before the work was done. There is no crank sensor under the timing belt cover like the dealer ship and another mechanic suggested what else should i look for ?
Feb 27, 2009 at 9:47 AM
BMRFIXIT
  • 19,053 POSTS
Recheck timing marks and firing order
check coil
Dec 20, 2016 at 3:11 AM
PITT51
  • 15 POSTS
How can i check the coil ?
BMRFIXIT
  • 19,053 POSTS
? Disconnect harness connector from Ignition Coil Power Output Stage (N157).
? Disconnect ignition wire from Ignition Coil (N152).
? Switch multimeter (Fluke 83 or equivalent) to resistance range.
? Connect multimeter between Ignition Coil terminals -1- and -15- and measure primary resistance.
? Primary resistance: 0.5-0.7 Ohms
? Connect multimeter between Ignition Coil terminals -4- and -15- and measure secondary resistance.
? Secondary resistance: 3000-4000 Ohms
If resistance values are not within the specified ranges:
? Remove Ignition Coil (N152) and replace Ignition Coil Power Output Stage (N157)..
? Repeat primary and secondary resistance checks.
PITT51
  • 15 POSTS
Ok now if the coil comes out ok and everything else is correct as far as the timing and firing order could it be anything else ?
BMRFIXIT
  • 19,053 POSTS
have a lot of possibilities
but You have to take it one step at a time
PITT51
  • 15 POSTS
ok coil checked out good found a broken wire on the distributor plug got new plug wired it back in still won't fire up. I'm about to take it in and have it fixed but really don't want too. What would be the next thing to check ?
BMRFIXIT
  • 19,053 POSTS
Do u have power at the coil
when key on ?
and you are sure that you have no spark
PITT51
  • 15 POSTS
Yes we are getting power at the coil when key is on and yes positive we are getting no spark.
BMRFIXIT
  • 19,053 POSTS
CAMSHAFT POSITION SENSOR, CHECKING Disconnect harness connector on Camshaft Position Sensor at Ignition Distributor. Connect Fluke 83 multimeter with adapter cables from VW 1594 to measure voltage across outer terminals of connector.
https://images.2carpros.com/forum/automotive_pictures/99387_vw_4.jpg
Switch ignition ON. Specified values: Up to 10.93 production, 49-states: 10 Volts min. Up to 10.93 production, California: 5 Volts min. From 10.93 production, all vehicles: 5 Volts min. If OK: Replace Ignition Distributor. See Ignition distributor, removing/installing . If NOT OK: Replace Motronic Engine Control Module (J220).
PITT51
  • 15 POSTS
Could u give me a pic of where the Motronic Engine Control Module is located the book i have don't show u much as far as location.
PITT51
  • 15 POSTS
what exactly is the Montronic Engine control module?
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_236.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_113.jpg
PITT51
  • 15 POSTS
ok replaced the coil along with the module that is attached to it .... just replaced the ecm and still no spark and getting no voltage at the plug for the distributor. What else can u think to check?
BMRFIXIT
  • 19,053 POSTS
Remove the distributor cap and crank engine does the rotor rotate ?
PITT51
  • 15 POSTS
Yes the rotor turns.
PITT51
  • 15 POSTS
I have already checked all the fuses and all were good. Is there any kinda relay,fuse,or fuseable link that could cause anything like this ?
BMRFIXIT
  • 19,053 POSTS
relay # 3
check it check for power
did u check the plug and wires into the dist.under the cap
PITT51
  • 15 POSTS
Yes the wires and plugs are fine matter of fact we had to take the plugs out yesterday cause we flooded it trying to get it started . Ok if the relay is getting power any way to tell if its bad ?
BMRFIXIT
  • 19,053 POSTS
Mark it and switch it with a similar one
u know that you have a crank sensor or engine speed sensor at the rear of the engine by the flywheel
you may wont’s to give it a check
PITT51
  • 15 POSTS
We know about the Crank sensor but we can't seem to find it anywhere .... do u have a pic that shows about where it is located ? we are having no luck finding it .
BMRFIXIT
  • 19,053 POSTS
check the picture i had sent
# 20
PITT51
  • 15 POSTS
Ok the relay #3 didn't change anything i even bought a brand new one is it possible that isn't the slot for it ? the Crank sensor is plugged in what else could i check?
BMRFIXIT
  • 19,053 POSTS
Disconnect connector from camshaft position sensor (ignition distributor)
check ohm between terminals 1+2
1+3 maximum resistance 1.5 ohm
if not replace
PITT51
  • 15 POSTS
Ok checked the terminals on distributor and checks out good . Now what could i check ? Remember i'm getting no spark.
BMRFIXIT
  • 19,053 POSTS
need to scan for codes
you had checked and tested every thing possible
have to check for codes
lets see what or where that will take us to!
PITT51
  • 15 POSTS
is there any way of jumpering some thing to get the codes with out scanner?
BMRFIXIT
  • 19,053 POSTS
Sorry I dont know of any if there is any
your is an OBDII ready check at your local part store if you can rent one .
**Is security light on ?
try to lock and unlock the door or the trunk using the key
_________________
Need a tool or a tester CHECK IT @
https://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
