My 1995 Jetta starts but cuts out. I've tried replacing the coil and fuel pump, and cleaned out the fuel tank. I have also replaced the plugs and checked engine compression. It seems okay at 165 PSI per cyl. I have tried fuel injection cleaner in fuel with no help. Check engine light comes on as engine is stalling. I was told it needs an oxygen sensor. Could this be the problem? Any other suggestions would be welcome.
Jan 14, 2008 at 10:19 AM
