1995 Volkswagen Jetta AC/Heat Blower Speed Controls
125,000 MILES • 4 CYL • FWD • MANUAL
CHRIS_HALL
I have a question pertaining to the knob that is responsible for controlling the output of the AC and heat and the speed setting of the blowers. The knob has settings 0 through 4. Over the past few months, I noticed that while running my air conditioning during the summer that the area around the knob with the knob included began to get extremely hot to the touch, so much so that it would have burned my fingers to touch it for more than a couple of seconds. Subsequently, air stopped being blown from the vents on the lower knob settings with the AC on. It would work on the higher ones. Now, in using my heat as the winter months have started, all of the knob settings have stopped working and no air (hot or cold) can be blown from the vents. I was wondering from all of this if this is somewhat of a straightforward problem that could be fixed without a long expensive trip to the repair shop or if it should be diagnosed more extensively before anything can be said for sure about it. I am very naive when it comes to car repair but would like to do what I can myself! Thanks!
--Christopher Hall
Jan 15, 2008 at 1:47 PM
QUYINN95HYUNDAI
Sounds like all you might need is a new blower motor switch you can go to the dealer or the autozone and order one. and then install it yourself. when you pull off the console cover the switch is connected to lego connector all you do is pop it off and then plug in the new switch. the heat you were feeling is from the switch shorting out and the electrical current being converted to heat.
[quote:76bdbeaf5e="chris_hall"]Air Conditioning problem
1995 Volkswagen Jetta 4 cyl Front Wheel Drive Manual 125000 miles
--Christopher Hall[/quote:76bdbeaf5e]
Jan 15, 2008 at 1:58 PM
