1995 Volkswagen Jetta A/C will not recharge
90,000 MILES • 4 CYL • FWD • MANUAL
MISSCHRISSY
Tried to recharge A/c myself...wouldn't work.
Took it to two auto shops...still wouldn't work.
One shop replaced the Expansion valve..no luck.
How can I fix this?
Jun 12, 2010 at 5:28 PM
  • 31,937 POSTS
Hi there, did the work shop pull the system down with a vacuum pump and did it hold a vacuum as per the recommended test procedure?
mark (mhpautos)
Jun 12, 2010 at 6:07 PM
MISSCHRISSY
Yes, they did use a vacuum pump to pull the system down and it showed no signs of leaks. For some reason it just won't take any of the refidgerant...but the guy at the shop showed me how his gauge was slightly moving back and forth which he said meant that the valve still works or it wouldn't move at all.
Jun 13, 2010 at 6:43 AM
  • 31,937 POSTS
If the system is holding a vacuum, but you can;t charger the system fully, i would be considering a faulty compressor.
Mark (mhpautos)
Jun 13, 2010 at 12:05 PM
