1995 Volkswagen Jetta
1995 VOLKSWAGEN JETTA
PRICANPAPI478
Computer problem
1995 Volkswagen Jetta 4 cyl Front Wheel Drive Automatic
I own a 1995 VW Jetta GLS and was looking forward to use it as a beginner in mechanical work but after having the car for a couple months the engine locked up so I purchased another engine 2.0l and had it put in and then the car did not want to turn on and I had a friend who is a mechanic tell me I needed a new computer so i bought one and installed it and the car turned on but then burned that computer as well what could be the problem?
Dec 19, 2009 at 6:50 PM
  • 31,937 POSTS
Hi there, you will need to do a continuity check of the loom feeds into the ECU. you may have a short to earth causing this expensive problem.
mark (mhpautos)
Dec 19, 2009 at 7:04 PM
