1994 Volkswagen Jetta Unexplained problem
85,000 MILES • 4 CYL • 2WD • MANUAL
SCREWSFALLOUT
Hi. I have a question about a problem I am having with my 1994 Volkswagen Vento. This is a European model that seems to be their version of the Jetta.
The problem I have is this: in the mornings, I can start the car with no problems. If I drive it for about twenty minutes then park and then try to start it again within about a half hour, the motor just won't turn over. It sounds like it is out of gas. Then, if I wait about 15-30 minutes, the car starts up just fine. Lately, the car has even stalled while running and then I have not been able to restart it again for about 30 minutes.
The only other thing I have noticed is that occasionally, I will notice that the engine is running much hotter than normal -- not quite to overheating, but definitely hot. I can't tell if this is related to the stalling/starting problem.
I have taken the car to my local VW dealer, but we couldn't replicate the problem. Any suggestions you have would be really appreciated.
Apr 24, 2008 at 3:29 AM
SERVICE WRITER
  • 9,123 POSTS
This is what I would suggest. The problem needs to be addressed when it is present, thus the Dealer's dlemma short of guessing...which is what I would be doing since it isn't happening.
So,You seem like you can predict this occurance according to this statement:
"The problem I have is this: in the mornings, I can start the car with no problems. If I drive it for about twenty minutes then park and then try to start it again within about a half hour, the motor just won't turn over. It sounds like it is out of gas. Then, if I wait about 15-30 minutes, the car starts up just fine. Lately, the car has even stalled while running and then I have not been able to restart it again for about 30 minutes."
So you need to talk to the service manager and talk to him about your special circumstance that pits you in a postion of needing testing at a particluar point. You set up an appointment and drive it to set the conditions needed and take it in and keep it running until the techs are ready, then shut it off. hopefully it doesn't start and they can verify the source.
Dec 20, 2016 at 4:05 AM
SCREWSFALLOUT
I can't make the car do it every time. I just want some idea of the parts that might be causing the problem. From my own research, I have come up with the following possibilities:
-Fuel Pump Relay
-Ignition Control Module
-Air Flow Sensor
Any other ideas?
SERVICE WRITER
  • 9,123 POSTS
It's kind of a broad spectrum. Anything that is affecting spark or fuel will cause this. I can name many parts that may be responsible, but it needs testing. Carry a fuel gauge and spark tester to start narrowing down the problem.
You can shoot some carb cleaner in the throttle body and see if it starts to put you onto the fuel los path as well.
MSM812
  • 5 POSTS
My 2000 Jetta has started doing the same thing. So far I haven't figured out the problem. But I'm trying. I'm no mechanic, this might take awhile.
If you have fixed yours or have any iother deas...
MSM
LISA7374
I am not a mechanic but my 1994 jetta had the same problem and after months of trying to figure it out it turned out to need a heat sheild installed over the starter and now has not had that problem sence. Dont know if it will help you but sheild does not cost very much and is fairly easy to put in
