1994 Volkswagen Jetta Cracked head?
1994 VOLKSWAGEN JETTA
100,000 MILES • 4 CYL • FWD • AUTOMATIC
NICHOLASJ
Thank you for the reply. how do I change the thermostat out. It's in the water pump housing off of the lower radiator hose. I dont have my chilton here and dont know what the proper way to approach.
Feb 21, 2008 at 11:05 AM
FLEXY5
  • 512 POSTS
The foamy/milky look under the cap is normal on some engines. I have a Ford that does the same thing. It happens when you get a little condensation in the valve cover from heating and cooling. It won't affect anything and since you say the oil looks good from the dipstick, the foaming is contained to the top portion of the engine. As far as the overheating, check for t-stat failure, radiator blockage, and cooling fan operation. Post back what you find and we'll go from there.
Feb 21, 2008 at 1:28 PM
2CARPRO JACK
  • 11,533 POSTS
My pics are pretty vague, but it looks like if you lift and support the front of the car, it is accessible from underneath
Feb 21, 2008 at 11:26 PM
