1993 Volkswagen Jetta car wont start
NANCY2674
Other Category problem
1993 Volkswagen Jetta 4 cyl Wheel Drive Type unknown Automatic 155000 miles
hi i have a car problem i was driving my car down the road the other day and it lost power and died and i am not able to get it restarted now idont knowwhat to do what could the problem be please help thank you
Feb 18, 2008 at 10:05 AM
HPARKHUSTLER
  • 11 POSTS
try giving it a tune-up....change spark plugs.distributor and distributor rotor..firing order from left to right is
1
2 3
4
thats how the wire should be let me know the results....whats it doing any power to lights?
Dec 20, 2016 at 3:16 AM
NANCY2674
yes i have power to my lights it just wont turn over
HPARKHUSTLER
  • 11 POSTS
since you power it might jus be your starter hit the starter wit a hammer or pliers see if it starts
NANCY2674
where is the starter actually located i will try it i hope it works
HPARKHUSTLER
  • 11 POSTS
if ur lookin at the enginge itll b on the left towards the back but under the intake manifold
ZEKEG
I have 1993 VW Corrado VR6 and had a similar issue. It would die as soon as I turned the car off and would not turn over; however my emergency lights started to flash. I found that the battery connection on the positive side was loose even though it did not look like it. I installed a new battery connector, tightened it on and it's worked fine ever since.
