1991 Volkswagen Jetta Car Will Not Start
180,000 MILES • 4 CYL • FWD • MANUAL
JOJOK1970
1991 VW Jetta GL 1.8l, engine turns over and is getting spark but will not start. Prior to not starting, idle was erratic jumping from 100 RPM's to 3,000.
Aug 10, 2008 at 9:23 AM
  • 75,988 POSTS
Do you have a check engine light prior to this problem?
Check your fuel pressure and comeback with the readings this is where we start.
Or you can use a carbuerator cleaner in the throttle body or carb and see whether it will fire up
Aug 10, 2008 at 9:34 AM
