1990 Volkswagen Jetta no start
UNRAUDAR
Electrical problem
1990 Volkswagen Jetta 4 cyl Front Wheel Drive Automatic
i have 1990 vw jetta that wont start with the key i replaced the ignition switch and replaced the starter when i turn the key on and jump the s terminal it will start but the alternator will only charge for awhile and then the stop not sure if its related.
Jan 28, 2010 at 11:35 AM
KHLOW2008
  • 41,812 POSTS
Hi unraudar,
Thank you for the donation.
When the ignition switch is turned to START, do you have battery voltage coming out of the Red/Bklack wire to the starter relay?
Does jumping terminal 2 and 8 cranks the starter?
Did you test the alternator main wire for bayttery voltage?
Was the alternator tested?
Dec 20, 2016 at 3:49 AM
