1990 Volkswagen Jetta no start
UNRAUDAR
  • 1990 VOLKSWAGEN JETTA
Electrical problem
1990 Volkswagen Jetta 4 cyl Front Wheel Drive Automatic
i have 1990 vw jetta that wont start with the key I replaced the ignition switch and replaced the starter when I turn the key on and jump the s terminal it will start but the alternator will only charge for awhile and then the stop not sure if its related.
Thursday, January 28th, 2010 AT 7:35 PM
KHLOW2008
  • 41,814 POSTS
Hi unraudar,
Thank you for the donation.
When the ignition switch is turned to START, do you have battery voltage coming out of the Red/Bklack wire to the starter relay?
Does jumping terminal 2 and 8 cranks the starter?
Did you test the alternator main wire for bayttery voltage?
Was the alternator tested?
Tuesday, December 20th, 2016 AT 11:49 AM
