1990 Volkswagen Jetta Grinding and knocking noises
150,000 MILES • 4 CYL • FWD • MANUAL
KNJNELSON
I was driving My 1990 VW Jetta 5 speed, When all of a sudden the car made a banging sound and it Felt as if the engin or the transmission fell out,(I felt it under the pedals and at the gear shift), the car still drives but it makes this grinding noise now almost like its rubbing on something. It also makes a knocking noise when I let up on the gas or put it in neutral to slow down. it doesnt matter if its in gear or not it still makes the noise. I cant see anything Visually wrong when i looked under the hood or under the car. Its made this Loud banging sound and felt like something from the engin fell off about 3 times since the 1st time, which is when the problem started.
Feb 27, 2010 at 1:43 PM
  • 31,937 POSTS
Hi there,
I feel that you have suffered a serious mechanical failure in the transmission or drive line, i would not drive this car, get it towed to a mechanic for a full inspection, if you drive it you may do far worse damage than what is there now.
mark (mhpautos)
Feb 27, 2010 at 1:51 PM
