2008 Volkswagen GTI HID lights
52,000 MILES • 4 CYL • FWD • MANUAL
GTI Y
when i start the car left HID blinks a few times and goes out completely. checked fuse, checked wiring and nothing. Just started a few days ago. Any help
Mar 22, 2010 at 5:14 PM
CARADIODOC
  • 34,413 POSTS
Unplug the bulbs and switch them side to side, then see if the same bulb acts up. Hopefully just the bulb will be burning out. They are only about 100 bucks. If the left side still has the problem, suspect the ballast. They are much more expensive than the bulbs.
Don't touch the glass part of the bulbs. The oil from your fingerprints will burn through the glass.
The fuses and wiring aren't the problem. When fuses blow, they don't start working again.
caradiodoc
Mar 24, 2010 at 8:44 PM
