2002 Volkswagen GTI TAIL LIGHT
2002 VOLKSWAGEN GTI
92,000 MILES • 4 CYL • FWD • AUTOMATIC
JJONES1972
I REPLACED MY LIGHT BULB IN THE DRIVERS SIDE TAIL LIGHT I ALSO REPLACED THE BULB HOLDER AND ALL OTHER LIGHTS WORK EXCEPT THE TAILLIGHT...ANY SUGGESTIONS
May 20, 2010 at 5:24 AM
VWTECH83
  • 39 POSTS
Make sure you use a VW bulb. I know it sounds funny, but have seen too many times a customer used there own bulb and when they did it caused a lot of funky things. Also make sure filament of bulb is facing the same way as the other bulbs. If any doubts it is a bulb problem, you can simply turn the lights on and check that you have a good power and ground to that terminal.
Sep 9, 2010 at 7:26 AM
