2002 Volkswagen GTI Radiator Fan
MSMCCORKLE
  • 33 POSTS
Engine Cooling problem
2002 Volkswagen GTI 4 cyl Front Wheel Drive Manual
My radiator fan is not turning on in my 2002 Volkswagen GTI. I'm thinking its the cooling fan thermo switch. Is that right? If so, how do i replace it?
Nov 1, 2010 at 3:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first you will want to check fuses and relay.
Nov 1, 2010 at 12:01 PM
MSMCCORKLE
  • 33 POSTS
I checked those already and everything was good. The fuses and the relay check out.
Nov 1, 2010 at 2:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, do you have the manual or auto A/C system so I can look at the correct wiring diagram of the cooling fan.
Nov 1, 2010 at 3:08 PM
MSMCCORKLE
  • 33 POSTS
Yes I do. I have the Hanes manual with the diagrams do I email it to you or how does that work?
Nov 6, 2010 at 5:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
No sorry I worded that wrong. I have the information already, I just needed to know if it was auto or manual A/C system. so you have the automatic a/c system?
Nov 6, 2010 at 7:35 AM
MSMCCORKLE
  • 33 POSTS
Yes it is the manual ac system. And I found that it is the wire that goes from the fuse box to the fan. Can I hook up the new wire from the battery directly to the fan and bypass the motor and relay? Or do I need to hook it up from the fuse box?
Nov 7, 2010 at 4:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
You will want to replace it in the same place, otherwise you will have to wire up a fused toggle switch and manually turn on/off the fan which is not the best of ideas because an overcooled engine is nearly as bad as an overhetaed engine.
Nov 7, 2010 at 4:10 PM
