1998 Volkswagen GTI Why isn't the high speed fan(radiator f
1998 VOLKSWAGEN GTI
192,000 MILES • 6 CYL • 2WD • MANUAL
DOUGFLASH007
  • 6 POSTS
I noticed for a couple weeks now that the high speed fan hasn't kicked in when the temperature reaches a high level.I replaced the high speed fan switch,I also replaced the fan control.What could possibly be causing this problem?Thanks greatly for your prompt response.
Apr 28, 2009 at 4:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you inspected the coolant fan fuse located behind battery, on the coolant fan control module?
Thanks for using 2CarPros.com!
Apr 28, 2009 at 4:28 PM
BSCHURR
  • 45 POSTS
have you checked the high speed cooling fan relay?
Jun 16, 2009 at 9:25 PM
