2005 Volkswagen Golf Headlight
100,000 MILES • 4 CYL • FWD • AUTOMATIC
OLDSALT111
How do you replace the driver side headlight??
Nov 7, 2008 at 3:42 AM
IMPALASS
  • 3,112 POSTS
Hello I have provided how to remove the headlight. I wasn't sure if you meant the head lamp bulb or the entire assemble so I included both. Headlights, Removing And Installing Removing CAUTION: Before beginning repairs on the electrical system: Switch off all electrical consumers. Switch ignition off and remove ignition key. Remove front bumper cover
https://images.2carpros.com/forum/automotive_pictures/248015_1_19.gif
Remove mounting screws -arrows-. Pull headlight housing out as far as electrical harness allows. Disconnect electrical connections. Remove headlight housing. Installing Install in reverse order of removal. Check and adjust headlight if necessary. Headlight Bulbs, Replacing Low Beam Headlight bulb -M29- / -M31-, replacing Removing CAUTION: Before beginning repairs on the electrical system: Switch off all electrical consumers. Switch ignition off and remove ignition key.
https://images.2carpros.com/forum/automotive_pictures/248015_2_25.gif
Release spring clip -arrow- and remove sealing cover.
https://images.2carpros.com/forum/automotive_pictures/248015_3_18.gif
Disconnect electrical connector -1- from bulb. Push retaining clip -2- over the lugs -3- and release. Pull bulb -4- out of reflector. Installing CAUTION: Do not touch glass portion of bulb with bare hands. Even the smallest amount of moisture and/or contaminants from fingers that evaporates on the bulb during operation can cause the glass to cloud over. Insert new bulb so lugs on bulb plate align with cut-outs in reflector. Connect electrical connector -1-. Install sealing cover. Check headlight (bulb) function. High Beam Headlight bulb -M30- / -M32-, replacing Removing CAUTION: Before beginning repairs on the electrical system: Switch off all electrical consumers. Switch ignition off and remove ignition key.
https://images.2carpros.com/forum/automotive_pictures/248015_4_14.gif
https://images.2carpros.com/forum/automotive_pictures/248015_5_9.gif
Disconnect electrical connection -1- from bulb. Push retaining clip -2- over lugs -3- and release. Pull bulb -4- out of reflector. Installing CAUTION: Do not touch glass portion of bulb with bare hands. Even the smallest amount of moisture and/or contaminants from fingers that evaporates on the bulb during operation can cause the glass to cloud over. Insert new bulb so lugs on bulb plate align with cut-outs in reflector. Connect electrical connector -1-. Install sealing cover. Check headlight (bulb) function.
Nov 7, 2008 at 3:16 PM
