Hello
I have provided how to remove the headlight. I wasn't sure if you meant the head lamp bulb or the entire assemble so I included both.
Headlights, Removing And Installing
Removing
CAUTION:
Before beginning repairs on the electrical system:
Switch off all electrical consumers.
Switch ignition off and remove ignition key.
Remove front bumper cover
Remove mounting screws -arrows-.
Pull headlight housing out as far as electrical harness allows.
Disconnect electrical connections.
Remove headlight housing.
Installing
Install in reverse order of removal.
Check and adjust headlight if necessary.
Headlight Bulbs, Replacing
Low Beam Headlight bulb -M29- / -M31-, replacing
Removing
CAUTION:
Release spring clip -arrow- and remove sealing cover.
Disconnect electrical connector -1- from bulb.
Push retaining clip -2- over the lugs -3- and release.
Pull bulb -4- out of reflector.
Installing
CAUTION: Do not touch glass portion of bulb with bare hands. Even the smallest amount of moisture and/or contaminants from fingers that evaporates on the bulb during operation can cause the glass to cloud over.
Insert new bulb so lugs on bulb plate align with cut-outs in reflector.
Connect electrical connector -1-.
Install sealing cover.
Check headlight (bulb) function.
High Beam Headlight bulb -M30- / -M32-, replacing
Removing
CAUTION:
Disconnect electrical connection -1- from bulb.
Push retaining clip -2- over lugs -3- and release.
Installing
Nov 7, 2008 at 3:16 PM
