2004 Volkswagen Golf WINDOW WIPPERS
40,000 MILES • 4 CYL • FWD • MANUAL
EMATGROGAN
THE CAR WINDOW WIPPERS WILL ONLY WORK WHEN THE CAR IS MOVING ALSO A LIGHT HAS COME ON TO THE DASHBOARD SAYING MY BONNET IS OPEN BUT IT IS CLOSED THANKS
Feb 18, 2009 at 6:46 PM
VLADGEISER
  • 66 POSTS
Try resetting the computer, to do this disconnect the negative terminal on your battery for approximately ten minutes. Reconnect and see if that fixes the wipers.
As for the hood, the battery thing may fix that but I suspect it is either a faulty switch or the switch has been somehow moved out of its mounting.
Mar 6, 2009 at 3:19 AM
