2004 Volkswagen Golf speedo/clocks
58,000 MILES • 4 CYL • 2WD • MANUAL
ROSEBALL
the remote central locking stopped working on the o/s rear door.i pulled all the fuses to see if ther was a broken fuse,all the fuses were good. i had to strip the door card and remove the locking arm. since then the speedometer dosent work,i have no reverse lights,every time i go round a corner the fuel gauge needle falls and the reserve light comes on,there is also an engine managment light on all the time. please help.
Feb 14, 2009 at 1:50 AM
VLADGEISER
  • 66 POSTS
You can get the check engine light checked for free at any Advance Auto, AutoZone, or Checker Auto.
It sounds like you may have a short in the system, you may want to go back into the rear hatch and look for grounded wires.
Mar 6, 2009 at 3:30 AM
